I just had my tyres pumped up to the correct pressure today. I'd always assumed it came from the shop correctly inflated, but I was amazed at the difference and how much faster it runs now! I love this bike even more
Garry
| About the A-Bike Where to Buy | Reviews Forum |
A-BIKE CENTRAL Home Page | Gallery & Videos Sinclair Bikes History | Other Folding Bikes A-Bike News (Blog) |
Garry wrote:Hi everyone, here's a useful tip for new A-Bike owners:
I just had my tyres pumped up to the correct pressure today. I'd always assumed it came from the shop correctly inflated, but I was amazed at the difference and how much faster it runs now! I love this bike even more![]()
Garry
laucnj wrote:hi,
i'm from singapore & have had my a-bike for over 2 weeks now. a question regarding the tyre pressure. will any type of bicycle pump work to inflate the a-bike tyres ? must i specifically buy a bicycle pump that has the correct valve ? thanks for any advise.
Amuro Lee wrote:Use a normal bicycle pump is okay. But I suggest you to buy a pump with a pressure gauge on it which can pump the tyres to the correct tyre prssure.
laucnj wrote:Amuro Lee wrote:Use a normal bicycle pump is okay. But I suggest you to buy a pump with a pressure gauge on it which can pump the tyres to the correct tyre prssure.
hey amuro, thanks for your advise. do you also know if the a-bike spare parts are readily available in hong kong now ?
Amuro Lee wrote:laucnj wrote:Amuro Lee wrote:Use a normal bicycle pump is okay. But I suggest you to buy a pump with a pressure gauge on it which can pump the tyres to the correct tyre prssure.
Hi laucnj,
A-bike spare parts are not available yet in the Hong Kong Web Site:
http://www.abike-shop.com/abike_parts.htm
However, I think we can contact the distributor in Hong Kong if there are damage parts which have to be replaced.
Here is the information of the distributor in Hong Kong:
MHM Marketing Co., Ltd.
Tel: (852)27598988
Fax: (852)27598778
website: http://www.abike-shop.com
email: mhm@mhm.biz.com.hk
Amuro
Izzard wrote:I've destroyed both of my wheels' tubes by being too rough with the valves. For some reason, I found it very hard to fit my Cyclaire pump to the valves - I had to push very hard to get it on enough to pump. It can also be quite fiddly lifting the right-angled valve away from the wheel to do this.
In my experimenting I pulled too much on the valves and tears have appeared where the valve is attached to the inner tube.
It's my own fault - I've ordered two new tubes (ouch - expensive) and I'll be more careful next time. Just to let you all know: because the valve is not attached to the wheel (eg with a locking nut), it can be pulled out too far where it snags on the edge of the hole in the wheel that it passes through.
Garry wrote:Actually there is a special kind of pump that is sold by Mayhem. I forgot the name, but it was discussed in this forum a long time ago, try searching this forum for "pump", for the full discussion. I don't know if a normal pump will work also but I suspect this one is much easier at least.
Garry
Users browsing this forum: No registered users and 26 guests
