Parts replacement on my A-bike
Postby Amuro Lee on Wed Nov 07, 2007 4:40 am
As an over-weight A-biker (115kg :oops:), my A-bike has been torturing by me for a whole year.
After a year of heavy duty on my little A-bike, the middle part of the tread of the rear tyre have been worn away.
There's a crack appearing on the rear lower tube, too.
When I tried to go up a steep incline by my A-bike last week, the chain fell off from the gear suddenly. After opening the crank case, a crack has been found on the small spocket of the layshaft.
Therefore, I had to replace the following parts:
Here are the prices of the parts from MHM, the local distributor of A-bike in Hong Kong.
Rear Lower Tube: HK$500
Layshaft: HK$125
得把口, an A-bike expert in the local A-bike community, has helped me to replace those parts. We just did it openly in a park last night. :P
My A-bike is recovered now.
Redundant parts
Postby newcross on Wed Nov 07, 2007 12:51 pm
Thank you for your report Amuro. I also experienced the crack on the tube and got parts from Mayhem then replaced it by myself (but new crack starting to appear...now it's about 5mm length.)
My case.
I found a hairline crack one day and it became bigger and bigger. I continued riding, the rear tube quick release clip snapped and whole thing got wobbly. Angle of the saddle and everything gone wrong. Please see below animation GIF I made. (I guess quick release was unclipped by my trousers then rear metal tube couldn't take the load with having the hairline crack, so the pipe started to tear and the crack opened, then a single screw of quick release was snapped by the force.
Since the rear upper tube is held by two button catches, my A-bike was somewhat ridable for a while even though it was very unstable --- so I could ride up to nearby pavement to save myself from cars. However, I saw reasonable numbers of reports on the crack on the net and thought there is a possible risk of fatal accident if users don't replace the cracked rear tube for long time.
(img. hairline crack on my A-bike)
(img. right after the incident. The opening of the crack was much bigger, but I pushed it back a little when I took this photo.)
Postby newcross on Wed Nov 07, 2007 1:04 pm
As far as I reckon, the crack will appear soon or later if your use A-bike regularly, even you take good care of your bike.
over tightening quick release clamp is absolute no-no. Although this cannot be the only cause for the crack, but this surely encourages the crack.
I already reported this cracking problem in document to Mayhem, Alex. K., Sir Clive at the London Meeting July 2007. Hopefully they will come up with some solutions.
Postby Amuro Lee on Mon Nov 19, 2007 7:45 pm
I found this picture on the post of disney's 3rd day journey on Jeju Island on the Naver Abike Cafe.
http://cafe.naver.com/dakaabike/2835
I think this is a good method to prevent the situation get worse.
Postby the other Guest on Tue Nov 20, 2007 2:00 am
Sorry me derailing. Not sure how to reach New Cross in any other way.
New Cross, is that an official CAD? based on A-bike site or did you do that one yourself. Looks so great to me who have no knowledge of how to make such.
I wish me could make such pictures too.
I refer to this one
00anime.gif as a guest I am not allowed to make such links
Which program does one need and do they save in gif or does one need a converter program to do that?
If you don't want to answer here in thred to write to
gaius.b at hotmail dot com
the other Guest
Postby newcross on Tue Nov 20, 2007 4:37 am
the other Guest wrote:New Cross, is that an official CAD? based on A-bike site or did you do that one yourself. Looks so great to me who have no knowledge of how to make such.
I refer to this one
Hi, the image looks great because the official A-bike image was great. I captured it from A-bike official online manual and altered it to simulate the incident by using photo editing software. "Animated GIF" canbe easily created by using freewares. To paste images (including GIF) here, you need to upload the image to a server (could be free photo host like Flickr) then just put the URL with Img tag you can see in the forum posting form.
In anyway, it's always good to register to this forum, so that you can post images and also send private message to other members of the forum. :wink:
Postby newcross on Tue Nov 20, 2007 4:47 am
Amuro Lee wrote:I found this picture on the post of disney's 3rd day journey on Jeju Island on the Naver Abike Cafe.
Amuro, thank you for re-upload the image to show us the disney's tip. (i still haven't managed to view the article properly :cry: , so this is really nice.) :D
the idea is fantastic!! I shall try this on my A-bike.
however I feel the metal strap should be put higher up to hold against the tube breaking load. :roll:
Postby newcross on Tue Nov 20, 2007 4:53 am
newcross wrote:however I feel the metal strap should be put higher up to hold against the tube breaking load. :roll:
I just realise it cannot go any further.... mmm... :?
Postby Amuro Lee on Tue Nov 20, 2007 5:26 am
Yes, you are right. It cannot go any further... :wink:
(This picture is also copied from the Korean A-bikers' :P)
Another part replacement on my A-bike
Postby Amuro Lee on Wed Dec 26, 2007 9:14 pm
The Upper Steering Joint Pivot Fixture of my A-bike broke recently. :(
I don't think it's the problem of the A-bike itself because I'm really a seriously overweight person (115kg :oops: ) as the recommended maximum user weight of A-bike is only 85kg and my A-bike has already been tortured by me for a whole year.
I've ordered the part from the local distributor. The price is HK$57 only.
Thanks to 得把口 for helping me to replace the part again!
The broken part
My A-bike is recovered again.
The rear lower tube has been strengthened by installing a stainless steel hose clip on it this time.
Postby kenwshmt2 on Wed Dec 26, 2007 9:40 pm
Should the rest of us do this as a preventative measure?
If we can find some straps that don't look to bad, it would be worth doing I think.
Postby Fai on Sat Dec 29, 2007 1:36 am
I think I will need Mr 得把口 help one day in the future because I really do not have any idea of how to repair or replace broken part of my A-bike. I would like to know how much is the service provided by Mr 得把口 ? (In the case you show us this time for example) Where is he/his shop?
Fai
Postby Amuro Lee on Sat Dec 29, 2007 9:21 am
Fai wrote:I think I will need Mr 得把口 help one day in the future because I really do not have any idea of how to repair or replace broken part of my A-bike. I would like to know how much is the service provided by Mr 得把口 ? (In the case you show us this time for example) Where is he/his shop?
I've given you his phone number. Do you remember that?
He is just an amateur bike mechanic.
You can phone him directly or e-mail him via lck98596842@yahoo.com.hk
Re: Parts replacement on my A-bike
Postby noodbix on Mon Jul 19, 2010 11:52 am
I highly suggest everyone should put that metal band called a tube clamp/ring around the rear tube.
For safety purposes, I put the clamp around both tubes near where the locking clasps are. That way, you can prevent any bad things from happening to the bike, short of the plastic breaking.
noodbix
Postby rp1733698@gmail.com on Sun Jun 19, 2016 1:05 pm
Upper Steering Joint Pivot Fixture of my A-bike is been broken so i need a new Upper Steering Joint Pivot Fixture of my A-bike .please, if anyone could help me with this part then please do e-mail at rp1733698@gmail.com
rp1733698@gmail.com
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 202 guests
