Removing the rear wheel?
Postby Ape on Tue Oct 23, 2007 8:50 pm
Hi, I have a genuine A-bike but the tyres were only pumpede to 30psi when it arived. I pumped the front tyre up to 90psi no problem. The rear tyre valve was not aligned properly (not poking out enough) to get the pump attached to inflate it properly (very anoying). The only way to fix this is to remove the rear wheel & deflate fully & re-alighn the valve.
My problem is I can only get one bolt out (right hand one) the other is well & truely stuck.
I have looked at the forums & it says the manual is wrong? & I do not understand the explenations? is the left hand bolt turned clockwise or counter clockwise?
Ape
Postby Amuro Lee on Wed Oct 24, 2007 7:15 am
I don't think you have to remove the rear wheel to inflate the rear tyre.
However, the inner tube will be torn easily if you pull out the valve too much when you are inflating the tyre, so I recommend you to use a pump with hose.
http://www.abikecentral.com/forum/viewtopic.php?t=547
Postby ape on Wed Oct 24, 2007 11:10 am
Thanks for your reply.
I have a pump with a hose but as thye valve was not in the corect position attaching the pump is not posible (it is to close to the hub).
I need to take of the rear wheel & the left hand bolt wont budge at all.
I am going to try to spray it with WD40 to loosen it, but I would like to know if it is definately clockwise I need to turn it?
ape
Postby Amuro Lee on Thu Oct 25, 2007 6:02 am
Could you post a photo here showing the valve position of the rear wheel of your A-bike?
Postby Ape1 on Thu Oct 25, 2007 12:05 pm
Thanks Amuro,
I managed to get my rear wheel off by following the video on the A-bike support group.
The left hand bolt turns clockwise not anti clockwise as stated in the instruction book.
Very anoying as in trying to get the wheel off I was holding the tyre & ripped the valve of my innertube! you MUST hold the wheel or this will happen.
I now have to wait for a new innertube & the fiddly bussiness of changing it untill I can try my new A-bike, very frustrating.
Ape1
Postby Amuro Lee on Thu Oct 25, 2007 12:55 pm
I'm sorry to hear about that. :(
Postby Amuro Lee on Thu Nov 01, 2007 9:11 pm
ape wrote:Thanks for your reply.
I have a pump with a hose but as the valve was not in the corect position attaching the pump is not posible (it is to close to the hub).
I still don't think you have to take off the rear wheel in order to inflate the rear tyre of your A-bike.
http://www.abikecentral.com/forum/viewtopic.php?t=623
Postby newcross on Mon Nov 05, 2007 3:44 pm
I think for ape in this case, the rear tyre just needed to be deflated in order to get the valve out from the hole on the rear wheel, and we don't need to use air pump to deflate --- we just need to use something like pen to push the pin in the centre of the valve to deflate.
Sundar Nagar Escorts
Postby riyabose on Thu Feb 05, 2026 12:16 pm
When you select an Sundar Nagar Escorts from our platform, you are choosing peace of mind. You know exactly who you are meeting, you can read about their personality, and you can be confident you are booking a top-tier companion.
riyabose
Re: Removing the rear wheel?
Postby wills on Thu Feb 12, 2026 9:18 am
The yt be activate enter the code portal makes streaming simple. Enter your code, confirm activation, and enjoy instant access to YouTube. Fast, secure, and designed for smooth entertainment.
With yt be activate enter the code, you can enjoy unlimited videos in minutes. Enter the code, confirm, and start streaming instantly. Easy, safe, and perfect for everyday entertainment.
The yt be activate enter the code process helps you connect quickly. Enter your code online, confirm activation, and enjoy instant access. Simple, secure, and convenient for all users.
Activate your device with yt be activate enter the code. Log in, enter the code, and start streaming instantly. Safe, reliable, and perfect for hassle-free entertainment.
The yt be activate enter the code option ensures smooth setup. Enter your code, confirm activation, and enjoy instant access to YouTube. Quick, secure, and convenient for everyone.
wills
Postby wills on Thu Feb 12, 2026 9:20 am
The yt be activate enter the code portal makes activation effortless. Enter your code, confirm details, and enjoy instant access to YouTube. Fast, reliable, and convenient for all users.
Activate your device quickly using yt be activate enter the code. This process ensures instant access to YouTube videos. Easy, secure, and perfect for hassle-free streaming.
The yt be activate enter the code option helps you connect instantly. Enter your code, confirm activation, and enjoy unlimited videos. Quick, safe, and designed for smooth entertainment.
With yt be activate enter the code you can start streaming in minutes. Enter your code online, confirm, and enjoy instant access. Simple, secure, and convenient for everyone.
The yt be activate enter the code process makes streaming effortless. Enter your code, confirm activation, and enjoy instant access to YouTube. Fast, reliable, and perfect for hassle-free entertainment.
wills
Postby wills on Thu Feb 12, 2026 9:22 am
Activate your device easily with yt be activate enter the code Log in, enter the code, and start streaming instantly. Safe, quick, and convenient for smooth entertainment access.
The yt be activate enter the code portal makes streaming easier. Enter your code, confirm activation, and enjoy videos instantly. Quick, safe, and designed for hassle-free entertainment for all users.
With yt be activate enter the code, you can link your account easily. Enter the code, confirm, and enjoy instant streaming. Simple, safe, and perfect for smooth entertainment.
Activate your device easily using yt be activate enter the code. This process ensures instant access to YouTube videos and subscriptions. Quick, safe, and convenient for everyone.
wills
Postby wills on Thu Feb 12, 2026 9:23 am
The discover.com activate credit card portal makes card activation simple. Log in securely, confirm your details, and start using your Discover card instantly. Quick, safe, and designed for hassle-free access to purchases, rewards, and account features.
With discover.com activate credit card, you can activate your card in minutes. Enter your information, confirm activation, and enjoy purchases, rewards, and account features. Easy, secure, and perfect for smooth financial management.
The discover.com activate credit card option helps you start using your card instantly. Activate online, confirm your details, and enjoy exclusive benefits. Fast, reliable, and designed for hassle-free customer experience.
Activate your Discover card quickly using discover.com activate credit card. This online process ensures instant access to your account, rewards, and purchases. Simple, secure, and convenient for everyone who wants to shop right away.
The discover.com activate credit card portal makes account setup effortless. Log in securely, enter your card details, and confirm activation. Fast, reliable, and designed for hassle-free financial management for all cardholders.
wills
Postby wills on Thu Feb 12, 2026 9:26 am
The discover.com activate credit card process makes account access simple. Log in securely, confirm your details, and enjoy instant access to purchases, rewards, and account features. Quick, safe, and designed for hassle-free use by all members.
Easily use discover.com activate credit card to manage your credit card. This online process is fast, secure, and convenient, giving you instant access to balances, rewards, and payment options.
With discover.com activate credit card, you can begin managing your finances with confidence. Enter your details, confirm login, and enjoy access to statements, rewards, and account features. Simple, secure, and perfect for members everywhere.
The discover.com activate credit card feature ensures easy access. Log in to manage payments, track balances, and view rewards instantly. Quick, reliable, and designed for smooth financial management.
Activate and manage your Discover card with discover.com activate credit card. Log in securely, track rewards, and pay bills instantly. Easy, safe, and convenient for hassle-free account management.
wills
Postby wills on Thu Feb 12, 2026 9:28 am
Manage your Discover card easily withdiscover.com activate credit card. Activate online, track rewards, and view statements instantly. It’s fast, secure, and perfect for smooth financial management without the hassle of phone calls or paperwork.
wills
Users browsing this forum: No registered users and 55 guests
