Hi, I have a genuine A-bike but the tyres were only pumpede to 30psi when it arived. I pumped the front tyre up to 90psi no problem. The rear tyre valve was not aligned properly (not poking out enough) to get the pump attached to inflate it properly (very anoying). The only way to fix this is to remove the rear wheel & deflate fully & re-alighn the valve.
My problem is I can only get one bolt out (right hand one) the other is well & truely stuck.
I have looked at the forums & it says the manual is wrong? & I do not understand the explenations? is the left hand bolt turned clockwise or counter clockwise?
